Change Brigthness option disappeared in Window Setting / Power Setting / everywhere. Newest...
Helfe beim Thema Change Brigthness option disappeared in Window Setting / Power Setting / everywhere. Newest... in Windows 10 Support um eine Lösung zu finden; I change the brightness from 100% to 50% because I was about to go blind from the strong brightness. However when I moved the bar from 100% to 50%... Dieses Thema im Forum "Windows 10 Support" wurde erstellt von qwerty3133, 27. September 2017.
  1. qwerty3133
    qwerty3133 Gast
    I change the brightness from 100% to 50% because I was about to go blind from the strong brightness. However when I moved the bar from 100% to 50% nothing changed. So I restarted the PC. After starting again still nothing changed. I go to change brightness but suddenly the whole settings of brightness disappeared everywhere. it is not there anymore. I HATE WINDOWS!
Change Brigthness option disappeared in Window Setting / Power Setting / everywhere. Newest... - Ähnliche Themen - Change Brigthness option
Settings change every reboot
Settings change every reboot: Hello everyone,so I have the problem that every single time I start my PC, the setting "show window content while dragging" gets disabled for some reason. Every single time I re-enable it and I dont know why it does it. It is really annoying and I hope you can help me fix this. What I already...
Windows 10 Support 21. Februar 2022
Change size of desktop in display settings
Change size of desktop in display settings: How can I change the size of the displays like shown below?I don't want to change screen resolution or scale of text and apps, just the size of these displays.Reason is that the borders between the screens, where you can switch over, are depending on this.In my example - display 1 is 1920x1080...
Windows 10 Support 21. Mai 2021
time setting
time setting: My time setting is always wrong. And that is so on my laptop and also on my desktop. All offered solutions don't work for me. So when is Microsoft going to solve this bug? Weiterlesen...
Windows 10 Support 29. April 2019
Window 10 1809 Language/Kezboard language settings
Window 10 1809 Language/Kezboard language settings: Windows 10 1809 build. I need to have language set to English/UK, but kezboard set to German. On line help searches refer to pre 1809 software builds which are not relevant. Weiterlesen...
Windows 10 Support 8. Oktober 2018
How to: Change Windows Update Settings in Windows 10
How to: Change Windows Update Settings in Windows 10: Windows Update is an service which allows the user to download and install updates. By default, the Windows Update behaivor is set to Automatic (recommended). If you are not happy with this default behaivor, here is how you can change this behaivor. Please read: Microsoft did an unexcepted...
Windows 10 Support 28. April 2018
System Settings Change
System Settings Change: Hallo, hab meinen Laptop ganz normal gestartet und hab diese "Fehlermeldung" bekommen. [IMG] ich hab schon nach einer Lösung gesucht wie z.B. der folgenden... [IMG] hat mir leider nichts gebracht, auch kein Neustart hat geholfen... Weiterlesen...
Windows 10 Support 25. April 2016
"ScanSnap Manager settings" Window wird nicht korrekt angezeigt
"ScanSnap Manager settings" Window wird nicht korrekt angezeigt: Das Fenster des Programms ScanSnap Manager Settings wird unter Windows 10 auf meinem Surface Pro 4 nicht korrekt angezeigt, wie auf dem unten eingefügten Bild zu sehen ist. Änderungen der Bildschirmauflösung sowie verschiedene Änderungen der Kompatibilitätseinstellungen zu diesem Programm...
Windows 10 Support 22. März 2016
remote desktop settings
remote desktop settings: Hallo, ich möchte meine PC's im Heimnetzwerk für den remote Zugriff freigeben. Laut Anleitungen müsste die Maske für die Settings folgendermaßen aussehen: [IMG] bei mir fehlt der untere Teil und die Maske sieht so aus: [IMG] irgend eine Idee, warum die Hälfte der Maske fehlt ?...
Windows 10 Support 14. Oktober 2015
Change Brigthness option disappeared in Window Setting / Power Setting / everywhere. Newest... [gelöst]
