Display problems Surface Laptop first generation for the second time!
Helfe beim Thema Display problems Surface Laptop first generation for the second time! in Surface um eine Lösung zu finden; Dear Sirs and Madams, I purchased a Microsoft Laptop for the first time back in 2018. At some point the display randomly started to open pages... Dieses Thema im Forum "Surface" wurde erstellt von Dilara Sahin, 3. Juli 2020.
  1. Dilara Sahin
    Dilara Sahin Gast
    I purchased a Microsoft Laptop for the first time back in 2018. At some point the display randomly started to open pages without me doing anything.
    This was during guarantee. So I got a new one. Obviously the new one wasn´t really new and now the Display broke just two months after the guarantee was still working. The Laptop never fell down or anything similar happenend. One of your supporters on the phone told me that the cause of it it`s only a Little crack in the inside of the Laptop, you can`t feel anything is because it wasn´t constructed the way it should be. Now you want 480 Euros for a Laptop that I bought for 1.200 Euros!!! How can that be possible??! And there isn`t even a real way to complain and tell somebody who holds a high position in the company!! I will not recommend this product to anyone!
    Thanks for your attention!
    #1 Dilara Sahin, 3. Juli 2020
Display problems Surface Laptop first generation for the second time! - Ähnliche Themen - Display problems Surface
Surface Laptop Studio does not detect the Thunderbolt Display
Surface Laptop Studio does not detect the Thunderbolt Display: I have following Surface Laptop Studio:11th Gen IntelR CoreTM i7-11370H @ 3.30GHz 3.30 GHz64-Bit-Betriebssystem, x64-basierter ProzessorI have an old thunderbolt display from apple with a built in TB2 cable. Connecting to the TB2 cable I have an apple TB2-TB3 adapter. My Surface laptop studio...
Surface 17. September 2024
The surface pen2 slim has two vibration options. What does the second option do?
The surface pen2 slim has two vibration options. What does the second option do?: In the settings of ther surface pen2, you can enable "vibrate while interacting with device" checkbox over intensity. What does this setting do. I dont seefeel any changes when activating it. :/I thought it would vibrate when i open or close windows on dekstop or drag an drop folders or...
Surface 6. September 2023
HDR and second display Monitor woes
HDR and second display Monitor woes: So I recently got a new monitor. All worked fine, till suddenly, after quitting a 640x480 fullscreen game, my primary monitor wasn't picked up. I reseated the cables, tried different ports, but for some reason, one monitor always wasn't picked up. Both were picked up and worked without any...
Windows 10 Support 15. Mai 2023
Surface Laptop 1te Generation Akku
Surface Laptop 1te Generation Akku: Hallo Zusammen, ich habe einen Surface Laptop der 1ten Generation Nun ist scheinbar der Akku platt er läd gar nicht mehr Laut meiner Recherche könnte es ein Softwareproblem sein. Empfehlung ist die Software zurück zu setzen, oder die aktuellste Firmware aufzuspielen. Beides geht nicht...
Surface 26. Oktober 2020
Surface 5. Generation Angebot
Surface 5. Generation Angebot: Ich interessiere mich für das Angebot "Surface Pro (5. Generation) + Platin Graufarbenes Signature Type Cover im Bundle". Welches Tastaturformat wird dabei geliefert? In der Fotogalerie sieht man das Type Cover ausschließlich im QWERTY-Format, ich hätte aber gerne die deutsche Tastatur (QWERTZ)....
Surface 15. September 2019
Surface Laptop (erste Generation)
Surface Laptop (erste Generation): Nach einem Update des Surface Laptops konnte ich mich weder mit der Gesichtserkennung noch mit dem Kennwort anmelden. Ich habe jetzt alles probiert, die Wiederherstellungsdaten auf einen Stick gepackt und versucht das Surface damit zurückzusetzen. Nach 98% kommt die Meldung "unbekannter...
Surface 26. November 2018
My friend has problems booting/installing Windows for first time
My friend has problems booting/installing Windows for first time: My friend just completed building his own pc. Here are the specs, if they matter: - AMD Ryzen 5 1600 - MSI PC-Mate B350 - ASUS Cerberus GTX 1070 ti - 16GB Ballistix Sport RAM - 1 TB HDD - 500GB Samsung 850 SSD He also bought an Windows 10 OEM key. The first time he started his...
Windows 10 Support 28. Juli 2018
Windows crashed the second time with the same bluescreen... "ntoskrnl.exe+16c580"
Windows crashed the second time with the same bluescreen... "ntoskrnl.exe+16c580": Hello folks! So my system crashed the second time, due to a MEMORY_MANAGEMENT BSOD. I looked at the dumpfiles with BlueScreenView, but "ntoskrnl.exe+16c580" is not a very helpful clue. Normally it tells almost directly what created the error, but not this time... I hope somebody of you is more...
Windows 10 Support 6. Januar 2018
Display problems Surface Laptop first generation for the second time! [gelöst]
