Replacement of Surface Pro 2 Cable went on fire
Helfe beim Thema Replacement of Surface Pro 2 Cable went on fire in Surface um eine Lösung zu finden; Where can i request a new surface pro 2 cable? It went on fire and I need a replacement. Apparently this is a known fire risk. Weiterlesen... Dieses Thema im Forum "Surface" wurde erstellt von Lea_331, 8. September 2023.
Replacement of Surface Pro 2 Cable went on fire - Ähnliche Themen - Replacement Surface Cable |
Processor replacementProcessor replacement: Ladies and gentlemen, I use Windows 10 Pro. on a PC, version 2004. The PC works with an Intel i5 processor. I would like to exchange this processor for an Intel i7, which is technically possible. Question: If my digital Windows 10 license expires, I will need to reinstall Windows 10 and, if... |
Windows 10 Support | 20. August 2020 |
Installing Disney+ on surface proInstalling Disney+ on surface pro: Split from this thread. Hallo, ich habe ein kleines Problem, wenn ich die zu installierende Disney + App im Microsoft Store auswähle. Ich werde aufgefordert, ein Gerät auszuwählen, aber dann wird angezeigt, dass mit meinem Microsoft-Konto keine anwendbaren Geräte verknüpft sind. Es bietet... |
Surface | 12. Mai 2020 |
Power Delivery of the USB Ports on Surface Pro 7Power Delivery of the USB Ports on Surface Pro 7: Hi everyone I do own a Surface Pro 7 i7 16GB RAM and 265GB storage. I do also own a Angelbird SSD PKT 2go. Do i use the USB-C Port there is no problem at all. But when i use the USB Type A Port there are a lot of connection problems so the SSD isn't recognized anymore. Do I connect it... |
Surface | 17. Dezember 2019 |
Surface Book 2 stays on 1803 which runs out of support soon.Surface Book 2 stays on 1803 which runs out of support soon.: My Surface Book 2 is on W10 1803. Windows Update indicates "no updates available", for all the reasons we know. Side remark: I'm using Adobe software which might play a role as this sw uses the graphics card. So far so clear and - in a sense - so good. However, the support for 1803 ends... |
Windows 10 Support | 10. Oktober 2019 |
Fusion 360 on Surface pro X (Windows on ARM)Fusion 360 on Surface pro X (Windows on ARM): Hey, I'm thinking about buying a Surface pro X, but one keypoint is Fusion 360 compatibility. Is there any way that I could know in advance if it works or not? I'm worried about it not working at all, but at least it should be better than on my current Pro 3. All the best Lorenz Weiterlesen... |
Windows 10 Support | 4. Oktober 2019 |
Surface pro replacementSurface pro replacement: Ich habe für ein defektes Surface (LTE-Funktion ging nicht mehr) ein noch defekteres Ersatzteil (stürzte zunächst mehrmals täglich ab; recovery-Versuch führte zu Totalversagen) bekommen. Beim Support verspricht man mir seit Tagen, dass dieses Gerät noch einmal ausgetauscht wird. Ich bekomme... |
Surface | 10. August 2019 |
Schwarz steht ihnen gut - Surface Pro 6 & Surface Laptop 2 Hands-OnSchwarz steht ihnen gut - Surface Pro 6 & Surface Laptop 2 Hands-On: Schwarz steht ihnen gut - Surface Pro 6 & Surface Laptop 2 Hands-On [ATTACH]Video: Microsoft hat mit dem Surface Laptop 2 und dem Surface Pro 6 bereits vor gut zwei Wochen seine diesjährige Neuauflage der beiden wichtigsten Produkte der hauseigenen Hardware-Sparte auf den Markt gebracht. Als... |
Windows 10 News | 1. November 2018 |
Fire TVStickFire TVStick: Immer wenn ich den wlan Schlüssel richtig eingegeben habe erscheint Anmeldung fehlgeschlagenen. Der Schlüssel ist aber richtig. Brauche hilft Weiterlesen... |
Windows 10 Support | 12. November 2017 |
