Battery charging -> watching a video -> the laptop becomes warm/ hot, CPU fan runs at high...
Helfe beim Thema Battery charging -> watching a video -> the laptop becomes warm/ hot, CPU fan runs at high... in Surface um eine Lösung zu finden; Hi, I have the following problem and I am pretty sure that is typical Surface Book 2 problem, everybody can reproduce it: Surface Book 2, 15 inch,... Dieses Thema im Forum "Surface" wurde erstellt von LaszloGyimothy, 8. Mai 2018.
  1. LaszloGyimothy
    LaszloGyimothy Gast
    Hi,
    Surface Book 2, 15 inch, RAM: 16 GB, SSD: 512 GB
    I have just reset my Surface and I have all of the updates.
    Test1:
    0. Power mode: Best performance, Wifi On
    1. plug the charging connector into the charging port on your Surface
    2. charge the battery to 100%
    3. DO NOT UNplug the charger
    4. close all of your running applications
    5. restart your laptop
    6. start the Edge browser
    7. navigate to youtube.com and start an HD or a higher quality video
    8. wait some minutes and your Surface becomes warm/ hot, CPU fan runs at high speed!
    9. set the power mode to battery saver and wait some minutes, everything is OK again
    10. set the power mode to best performance again and wait some minutes, your Surface becomes warm/ hot, CPU fan runs at high speed!
    Test2:
    1. DO NOT plug the charging connector into the charging port on your Surface
    2. use your Surface and wait until the battery is below 98%
    3. DO NOT plug the charger
    8. wait some minutes and everything is OK again
    9. plug the charging connector into the charging port on your Surface
    10. charge the battery to 100%
    11. your Surface becomes warm/ hot, CPU fan runs at high speed!
    Test3:
    8. put your Surface (the tablet part) close to your ears, you can hear a very silent noise!
    10. put your Surface (the tablet part) close to your ears again , you cannot hear this noise anymore!
    Any idea? What could be the problem?
    #1 LaszloGyimothy, 8. Mai 2018
Battery charging -> watching a video -> the laptop becomes warm/ hot, CPU fan runs at high... - Ähnliche Themen - Battery charging watching
run the onedrive troubleshooter
run the onedrive troubleshooter: Meine Dateien in Word sollen nicht in One Drive gespeichert werden. 1. Wenn ich eine One Drive Datei lösche, ist sie auch in Word oder Excel verschwunden. 2. Selbst wenn ich eine Adobe Datei Zeugnis, Promotion suche, stelle ich fest, dass diese auch in One Drive gespeichert istWas soll dieses...
Windows 10 Support 21. Dezember 2023
run the onedrive troubleshooter: Hallo, ich habe heute mein neues Surface gekommen!Das neue Surface möchte meine Einstellungen, OneDrive-Dateien und häufig verwendete Apps synchronisieren.Die Grundlage dafür soll eine "letzte Synchronisierung vom 12. Dezember 2022" sein! Das ist mir völlig unbegreiflich!Wie kann ich die...
Windows 10 Support 27. Juli 2023
CPU zu warm
CPU zu warm: Hallo zusammen, ich habe ein Problem mit meine CPU beim starten des Rechners. Zuerst aber ein paar Infos. Der Rechner ist ca.6 Jahre alt und läuft ca. 2 Stunden am Tag[ATTACH] Hier sollte alles wichtige stehen. Mein Problem: Ich schalt den Rechner an und der Rechner will nicht starten. Beim...
Windows 10 Treiber & Hardware 1. April 2021
CPU teilweise 100Grad warm
CPU teilweise 100Grad warm: Hallo Leute ich habe ein Surface pro vier bei dem sich die Akkus aufgebläht haben vermutliche Ursache zu heiß. Akkus habe ich erfolgreich getauscht bei dem Einblick ins Innenleben wurde mir klar wie ich die Akkus wurden heiß sondern die CPU jetzt habe ich mir eine Temperaturüberwachung für Den...
Surface 20. August 2020
Akku laden -> Video anschauen -> der Laptop wird warm / heiß, CPU-Lüfter läuft mit hoher...
Akku laden -> Video anschauen -> der Laptop wird warm / heiß, CPU-Lüfter läuft mit hoher...: Hallo, Ich habe das folgende Problem und ich bin ziemlich sicher, dass das typische Surface Book 2 Problem ist, jeder kann es reproduzieren: Surface Book 2, 15 Zoll, RAM: 16 GB, SSD: 512 GB Ich habe gerade mein Surface zurückgesetzt und ich habe alle Updates. Test1: 0. Power-Modus: Beste...
Surface 17. Mai 2018
after battery change battery is not charging anymore
after battery change battery is not charging anymore: Windows 10 latest update installiert. Ultrabook Toshiba Satellite Z930-130 (4-5 years old) new OEM battery replaced the old one. but it is not charging. reinstalled old battery: not charging. followed the recommendation in internet: take out the battery de-install the battery driver...
Windows 10 Support 4. Februar 2017
after battery change battery is not charging anymore.
after battery change battery is not charging anymore.: Windows 10 latest update installiert. Ultrabook Toshiba Satellite Z930-130 (4-5 years old) new OEM battery replaced the old one. but it is not charging. reinstalled old battery: not charging. followed the recommendation in internet: take out the battery de-install the battery driver...
Password at the Startscreen
Password at the Startscreen: Hello I have an simple Question. I made an Microsoft-account and now I have to log in every time I start my PC. What could I do to dont have any Password at my Startscreen how can I deactivate the Password. Weiterlesen...
Windows 10 Support 15. Januar 2017
Battery charging -> watching a video -> the laptop becomes warm/ hot, CPU fan runs at high... [gelöst]
