BSOD - Where is the problem? DRIVER_POWER_STATE_FAILURE
Helfe beim Thema BSOD - Where is the problem? DRIVER_POWER_STATE_FAILURE in Windows 10 Support um eine Lösung zu finden; Hi there, recently I had some problems with my Lenovo T440p laptop. In 9 out of 10 times starting takes forever (sometimes more than 5 minutes) and... Dieses Thema im Forum "Windows 10 Support" wurde erstellt von Marie Crossroad, 6. Juni 2016.
  1. Marie Crossroad
    Marie Crossroad Gast
    Hi there,
    recently I had some problems with my Lenovo T440p laptop. In 9 out of 10 times starting takes forever (sometimes more than 5 minutes) and maybe once a week I have a BSOD error. I used BlueScreenView to show the log, but could not deduce anything from it. I know there are many threads about that topic, but none of them helped me so far. I recently updated bios, installed newest power management drivers from Lenovo, all didn't help. I also did a memtest and check disk, without any error messages. I would be happy if anyone could help me here.
    Dump File : 060116-2040234-01.dmp
    Crash Time : 01.06.2016 08:16:21
    Bug Check String : DRIVER_POWER_STATE_FAILURE
    Bug Check Code : 0x0000009f
    Parameter 1 : 00000000`00000003
    Parameter 2 : ffffe001`493897e0
    Parameter 3 : ffffd001`3deae990
    Parameter 4 : ffffe001`5e61ec10
    Caused By Driver : ntoskrnl.exe
    Caused By Address : ntoskrnl.exe+142780
    File Description : NT Kernel & System
    Product Name : Microsoft® Windows® Operating System
    Company : Microsoft Corporation
    File Version : 10.0.10586.306 (th2_release_sec.160422-1850)
    Processor : x64
    Crash Address : ntoskrnl.exe+142780
    Stack Address 1 :
    Stack Address 2 :
    Stack Address 3 :
    Computer Name :
    Full Path : C:\Windows\Minidump\060116-2040234-01.dmp
    Processors Count : 8
    Major Version : 15
    Minor Version : 10586
    Dump File Size : 948.804
    Dump File Time : 01.06.2016 08:51:32
    Thanks a lot.
    #1 Marie Crossroad, 6. Juni 2016
    • Sample Page
      Sample PageThis is an example page. It's different from a blog post because it will stay in one place and will show up in your site navigation (in most themes). ...
    • Fehler 0x80248007 bei Windows Update beheben
      Fehler 0x80248007 bei Windows Update behebenDer Fehler 0x80248007 kann unter Windows 10, 7 und 8 auftreten, wenn Sie ein Update installieren. Wir zeigen Ihnen die Lösung den Fehler zu beheben. ...
    • 0x80070490 Windows Update Fehler beheben
      0x80070490 Windows Update Fehler behebenWenn der Fehler 0x80070490 unter Windows Update auftritt, ist der Dienst beschädigt. Wir zeigen Ihnen, wie Sie das Problem lösen können. Windows U...
BSOD - Where is the problem? DRIVER_POWER_STATE_FAILURE - Ähnliche Themen - BSOD Where the
BSOD DRIVER_POWER_STATE_FAILURE
BSOD DRIVER_POWER_STATE_FAILURE: Guten Tag alle ich habe mehrere Lenovo L14s gen3 MTM 21CQ die in unregelmässigen abständen beim Herunterfahren des Windows 10 einen BSOD auslösen.Ich denke es liegt an einem Treiber ich komme aber nicht dahinter welcher. Ich habe alle Treiber mit Lenovo Vantage aktualisiert.Dump...
Windows 10 Support 23. Januar 2024
What does this mean? Where is the problem? Page Fault in non pagged Area Error
What does this mean? Where is the problem? Page Fault in non pagged Area Error: Hello,After switching to an AMD Graphic Card, I am getting blue screens. Even after connecting the NVIDIA Graphic Card again, Bluescreens happen and I do not know why. Everything started since I switched Graphic Cards.With WinDbg Preview I analysed the minidump file and this came out:Can someone...
Windows 10 Support 21. April 2023
BSOD DRIVER_POWER_STATE_FAILURE: Hallo, ich besitze 3 Lenovo x240 Notebooks, die derzeit alle unter W10 21H2 laufen. Alle 3 Notebooks haben das Problem, dass in unregelmäßigen Abständen BSOD-Fehler auftreten. Allerdings trat der Fehler auch bei früheren Windows 10 Versionen auf. Die Fehlermeldung lautet immer...
Windows 10 Support 4. Juni 2021
DRIVER_POWER_STATE_FAILURE: Habe seit kurzer zeit wenn ich den PC Neustart ein Bluescreen nach ca. 10 minuten oder so, und danach kommt immer diese DRIVER_POWER_STATE_FAILURE Statuscode Meldung. Hier wäre eine Minidump datei bei deisen OneDrive link dabei falls das etwas Hilft....
Windows 10 Support 19. Oktober 2020
Windows 10 BSOD DRIVER_POWER_STATE_FAILURE
Windows 10 BSOD DRIVER_POWER_STATE_FAILURE: Moin, seit einiger Zeit tritt auf meinem Laptop immer wieder ein BSOD auf. Dazu gehört in erster Linie der oben genannte aber auch DXGKRNL_FATAL_ERROR. Ich habe online bereits nach Lösungen gesucht und keine Gefunden. Der Laptop ist ein Asus Zenbook 13 UX331U. Unter dem folgenden Link sende...
Windows 10 Support 20. April 2020
whats is the Tab "Graphics_1" (GPU) in the Taskmanager?
whats is the Tab "Graphics_1" (GPU) in the Taskmanager?: For what is the tab "Graphics_1" in the Gpu submenu in the Taskmanager? Which part of the gpu does is represent? What uses this part of the gpu? [ATTACH] Weiterlesen...
Windows 10 Support 24. März 2019
Where is the windows insider forum?
Where is the windows insider forum?: I am german but would like to be in the us insider forum. Can not find a link. where is it?
Windows 10 Insider 9. April 2015
Windows 10: BSOD DRIVER_POWER_STATE_FAILURE
Windows 10: BSOD DRIVER_POWER_STATE_FAILURE: Hallo zusammen, bekomme seit neuestem den Fehler Driver Power State Failure beim Verwenden von Streamingdiensten wie Netflix und Amazon Prime. BUG CHECK STRING: DRIVER_POWER_STATE_FAILURE BUG CHECK CODE: 0x0000009f Arbeitsspeicher wurde bereits getestet. Test lief nicht durch. EDIT: RAM Test...
Windows 10 Support 12. November 2017
BSOD - Where is the problem? DRIVER_POWER_STATE_FAILURE [gelöst]
