Issue while auto opening SAP GUI/third party application through EDGE browser
Helfe beim Thema Issue while auto opening SAP GUI/third party application through EDGE browser in Microsoft Edge um eine Lösung zu finden; Hello All, This is regarding connection to SAP GUI through an agnostic file in BI launchpad. Steps: In SAP GUI, if we want to connect to a... Dieses Thema im Forum "Microsoft Edge" wurde erstellt von Nair Sayujya - Munich-MR, 28. Februar 2020.
  1. Nair Sayujya - Munich-MR
    Nair Sayujya - Munich-MR Gast
    Hello All,
    Steps:
    In SAP GUI, if we want to connect to a workbench or area directly, we can give its reference in BI launchpad with the help of an agnostic file.
    Go to the workbench through SAP GUI and add it to favorites and then to desktop locally.
    Now going to BI launchpad and create local document, add this to launchpad
    On clicking on this agnostic file, it should directly lead to the workbench in the SAP GUI.
    But this doesn't seem to be working with EDGE browser. It simply displays information about the file.
    However it works with Internet explorer.
    Is there any workaround so that they directly open in the application GUI here
    Thanks,
    Sayujya.
    #1 Nair Sayujya - Munich-MR, 28. Februar 2020
  3. Sabine
    Sabine Windows Kenner
    3. Januar 2016
    Asked SAP!
Issue while auto opening SAP GUI/third party application through EDGE browser - Ähnliche Themen - Issue while auto
Windows 10 "Logon GUI Application 100%"?
Windows 10 "Logon GUI Application 100%"?: Mein Problem ist wenn ich ein Game spiele und austabbe dann geht die Anwendung "Logon GUI Application" auf 100% und wenn ich dann eintabe habe ich dann ca 2min laggs bis es dann wieder geht. Was kann ich da machen? Den Prozess beenden bringt auch nix, startet sich ja immer wieder neu....
Windows 10 Support 28. Dezember 2020
List of Windows 10 on ARM drivers / available third party accessories?
List of Windows 10 on ARM drivers / available third party accessories?: Hi, Is there a list of drivers for Windows 10 on ARM available? I am searching for accessories for Windows ARM devices. In particular a docking station. As far as I know, there are drivers for: - Microsoft Surface USB Ethernet Adapter - DisplayLink USB to HDMI Adapter (has a high CPU...
Windows 10 Support 13. Juni 2019
Auto-Play von Videos im Edge-Browser während der Einrichtung des Funktionsupdates für...
Auto-Play von Videos im Edge-Browser während der Einrichtung des Funktionsupdates für...: Nach der erfolgreichen Installation des Updates und folgendem Neustart kam nach dem Anmeldebildschirm ein längerer Dialog, bei dem der Nutzer aufgefordert wurde, zu einer großen Anzahl von Fragen anzugeben, welchen Modus er haben möchte. (Die Fragen reichten von Zustimmung zur Spracherkennung...
Windows 10 Support 11. Juni 2018
Fehler 0x8007007b bei Installation von SAP GUI Frontend auf WINDOWS 10 Rechner
Fehler 0x8007007b bei Installation von SAP GUI Frontend auf WINDOWS 10 Rechner: Hallo, ich erhalte folgende Fehlermeldung bei der Installation des SAP GUI Frontends auf einem Windows 10 Rechner: "Die Syntax für den Dateinamen, Verzeichnisnamen oder die Datenträgerbezeichnung ist falsch." (0x8007007b). Ich musste Win10 neu installieren. Fehler ist bei der erneuten...
Windows 10 Support 19. Dezember 2017
Könnt ihr mal aufhören Third-Party-Antivirus Programmen die Schuld zu geben?
Könnt ihr mal aufhören Third-Party-Antivirus Programmen die Schuld zu geben?: Guten Tag Mir macht es Spaß anderen Leuten zu helfen da manche irgendwie komische oder unlogische antworten liefern(und da tut es manchmal weh wenn ihnen nicht richtig geholfen wird (Problembehandlung hust hust) -.- Was mich zum weinen bringt ist warum bei jeden kleinsten Fehler direkt...
Windows 10 Support 5. Dezember 2017
Edge Browser
Edge Browser: Hallo, nach dem neusten Update (2017) werden im Microsoft Edge 40.15063.0.0 die importierten Favoriten angezeigt, aber diese verschwinden wie von Geisterhand aus der Favoritenleiste nach einer Weile von selbst. Was kann ich tun oder bzw. wo liegt der Fehler? So das meine Favoriten dauerhaft...
Windows 10 Support 11. Mai 2017
Cortana search not opening browser
Cortana search not opening browser: When I search in Cortana and press on a result no browser opens with it. I reset browsers (Chrome and Edge installed) did sfc /scannow Malwarebytes scans What can I do? Happened on creator's update but now also with the newest insider build. Weiterlesen...
Windows 10 Support 23. April 2017
Browser Edge
Browser Edge: Beim starten des Browser Edge, öffnet sich die Favoritenleiste (eingeschaltet) mit den online Seiten nur mit Sternen an Stelle von Icons. Seit dem Update auf 1511. Weiterlesen...
Windows 10 Support 14. November 2015
Issue while auto opening SAP GUI/third party application through EDGE browser [gelöst]
