Keyboard does not work in the left top corner
Helfe beim Thema Keyboard does not work in the left top corner in Surface um eine Lösung zu finden; Hello everyone, I have a problem with the keyboard. This is the German keyboard in a 13" Surface Book 2 with i7 and 512 GB SSD. The keys in the top... Dieses Thema im Forum "Surface" wurde erstellt von Peter Gelber, 20. Januar 2024.
  1. Peter Gelber
    Peter Gelber Gast
    Hello everyone, I have a problem with the keyboard. This is the German keyboard in a 13" Surface Book 2 with i7 and 512 GB SSD. The keys in the top left corner:"F1", "F2", "F3","F4", "F5" q, w, e, r, ta, s, d, f, "space"no longer work. I think I've tried a lot of suggestions offered, and since all the other buttons work, and at the moment I can hardly imagine that it's a software issue. I also docked and undocked it and cleaned it. External keyboard via USB works without any problems.I can also easily switch the background lighting on/off for all keys. I had the option to dock the keyboard
    #1 Peter Gelber, 20. Januar 2024
    • Sample Page
      Sample PageThis is an example page. It's different from a blog post because it will stay in one place and will show up in your site navigation (in most themes). ...
    • Fehler 0x80248007 bei Windows Update beheben
      Fehler 0x80248007 bei Windows Update behebenDer Fehler 0x80248007 kann unter Windows 10, 7 und 8 auftreten, wenn Sie ein Update installieren. Wir zeigen Ihnen die Lösung den Fehler zu beheben. ...
    • Windows 10: Automatische Anmeldung ohne Passwort
      Windows 10: Automatische Anmeldung ohne PasswortWenn Sie Windows 10 ohne Passwort verwenden wollen, können Sie den Eintrag mit der automatischen Anmeldung einfach umgehen. Unsere Anleitung zeigt Ih...
  3. hal9000
    Code:
    https://answers.microsoft.com/de-de/surface/forum/all/keyboard-does-not-work-in-the-left-top-corner/b5986f96-a706-4b69-abf8-a450e0a8d3c9
Keyboard does not work in the left top corner - Ähnliche Themen - Keyboard does not
Surface Laptop Studio does not detect the Thunderbolt Display
Surface Laptop Studio does not detect the Thunderbolt Display: I have following Surface Laptop Studio:11th Gen IntelR CoreTM i7-11370H @ 3.30GHz 3.30 GHz64-Bit-Betriebssystem, x64-basierter ProzessorI have an old thunderbolt display from apple with a built in TB2 cable. Connecting to the TB2 cable I have an apple TB2-TB3 adapter. My Surface laptop studio...
Surface 17. September 2024
Microsoft Store search page does not work FIX
Microsoft Store search page does not work FIX: When I search for something in the Microsoft Store, the search page is not displayed. Instead, the page loads indefinitely. Only the limited result display as a dropdown is shown. Everything else works without problems.Windows 10 version 22H2 OS Build 19045.4046Microsoft Store Version...
Windows 10 Support 23. Februar 2024
User profile cannot be loaded plus Safe mode does not work after resetting the pc
User profile cannot be loaded plus Safe mode does not work after resetting the pc: After resetting my windows computer, I tried to log in to my user account but I got User profile cannot be loaded error. So I tried to switch to safe mode to fix the problem, but safe mode doesn't work either. When I enter my credentials there, it keeps loading and nothing happens.What can I do...
Windows 10 Support 16. September 2022
Windows 10 Pro Produkt Key does not work anymore
Windows 10 Pro Produkt Key does not work anymore: Hi,I had a running Windows 10 Pro installation for several years.I reinstalled my laptop now with windows 10 again.After reinstalling i cannot activate windows with my windows 10 pro product key.Windows 10 home is activated and linked to my microsoft account, but i cannot activate my working for...
Windows 10 Support 20. Februar 2022
Tastatur funktioniert nicht / Keyboard does not work
Tastatur funktioniert nicht / Keyboard does not work: Suddendly the Hardware keyboard has given up Maybe we pressed the wrong key-combination? Yet none of the suggestions helped Plötzlich funktioniert die Tastatur nicht mehr. Keine der Vorschläge funktionieren Medion 3216 Weiterlesen...
Windows 10 Support 20. Dezember 2020
Surface Pen: rubber works, but not the tip
Surface Pen: rubber works, but not the tip: Hello Microsoft Team, I have a problem with my Surface pen: The rubber works, but not the tip. The problem occured before twice, once with the same, once with a different pen. My device is the Surface Go and I have a "Surface pen with no clip". The batteries are full. I tried removing them...
Surface 14. Dezember 2020
Windows button does not work.
Windows button does not work.: I have read many of the articles about this issue. I have tried several of the proposed solutions; none have worked including SFC, DISM, and Get-AppXPackage. I've rebooted my laptop after each attempted fix with no luck. I have read that I can try to use repair / restore, but that may be loose...
Windows 10 Support 31. Dezember 2017
After Windows 10 Creators Update Flash does not work
After Windows 10 Creators Update Flash does not work: Hello, after having updated Windows 10 wit the Creators update Web-pages using Adobe Flash are not working correctly anymore. In Edge-extended settings I have activated the use of Adobe Flash. I've searched for Flash in Windows Apps and features and could not find it. Any trial to...
Windows 10 Support 10. April 2017
Keyboard does not work in the left top corner [gelöst]
