Project to Beamer no connection (LG PF1500G - Surface Book Pro)
Helfe beim Thema Project to Beamer no connection (LG PF1500G - Surface Book Pro) in Surface um eine Lösung zu finden; LG PF1500G - Surface Book Pro For some time (I do not know since when - maybe one year) I cannot connect my Surface Book with an LG PF1500G... Dieses Thema im Forum "Surface" wurde erstellt von Ich habs satt, 7. März 2019.
Project to Beamer no connection (LG PF1500G - Surface Book Pro) - Ähnliche Themen - Project Beamer connection |
Printer connection to laptopPrinter connection to laptop: Since weeks I've been trying to connect my 5 year old HP ENVY 5530 all-in-one printer with my even older Lenovo laptop which is updated to Windows 10 though - to NO avail! All drivers are updated on both devices - I have tried to run HP Print & Scan Doc to find out the mistake/s - no connection... |
Windows 10 FAQ | 9. August 2022 |
Project to Surface Pro7 not workingProject to Surface Pro7 not working: Hi there, I recently purchased the Surface Pro7 and would like to use it as a secondary screen for my PC. So far I only succeeded in using my PC as a secondary screen for the Surface via Miracast. When I try it the other way round, my PC is not able to detect the Surface in the list of... |
Windows 10 Support | 27. November 2020 |
Repeated connections to ocsp.digicert.comRepeated connections to ocsp.digicert.com: Just noticed that many Windows apps, includig SeachApp.exe repeatedly connect to http://ocsp.digicert.com/[ininfite series of numbers and letters], a website that I cannot identify as being malicious or safe by my research resuls vary greatly. Can anyone help? Weiterlesen... |
Windows 10 Sicherheit | 24. November 2020 |
Surface Book 2 kabellose Verbindung zu einem BeamerSurface Book 2 kabellose Verbindung zu einem Beamer: Hallo zusammen, zum Arbeiten habe ich seit kurzem ein Surface Book 2 mit Docking Station. Bei Bildschirm- und Beamerpräsentationen gehe ich aktuell mit einem zusätzlichen Adapter von der Docking Station auf den entsprechenden HDMI Anschluss. Neben den reinen PP-Präsentationen möchte ich auch... |
Surface | 20. Dezember 2019 |
Surface Book 2 mit LG 31MU97Z hat nicht die volle AuflösungSurface Book 2 mit LG 31MU97Z hat nicht die volle Auflösung: Hallo alle zusammen, ich habe ein Surface Book 2 (Mitte 2018 gekauft) über das Surface Dock (gekauft 2016 mit dem Surface Book 1) per Mini Display Port zu Mini Display Port an einen LG 31MU97Z angeschlossen. Bisher hatte ich dabei die volle Auflösung (4096 x 2160). Nun habe ich (leider) ein... |
Surface | 10. April 2019 |
Wireless Verbindung des Surface pro mit einem BeamerWireless Verbindung des Surface pro mit einem Beamer: Hallo, ich habe ein surfache pro und möchte den Bildschirminhalt drahtlos auf einen Kurzdistanzbeamer schicken. Dieser hat neben apple TV auch noch HDMI-Eingänge frei, die aber der Zugänglichkeit wegen nicht direkt am Gerät sind, sondern über ein Zwischen-HDMI-Kabel an einer Wandbuchse sitzen.... |
Windows 10 Support | 31. August 2018 |
Surface Book Perfomance Base gibt bei Beamer kein Signal ausSurface Book Perfomance Base gibt bei Beamer kein Signal aus: Hallo Zusammen Bei uns im Geschäft verteilen wir den Usern als Arbeitsgeräte Surface Books. Nun hatte ein User das Problem, als er Extern eine Powerpoint-Präsentation zeigen wollte wurde diese Präsentation nicht auf dem Beamer angezeigt. Ich habe darauf getestet ob dieses Problem Intern mit... |
Surface | 4. Mai 2018 |
No Connection with the EthernetNo Connection with the Ethernet: Im German and so I writh it in my language Mein Computer ist zwar mit dem LAN-Kabel verbunden, doch es steht da, dass das Netzwerk nicht identifiziert ist und das ich keine Internetverbindung habe. Das selbe ist mit meinem WLAN, nur dass ich damit verbunden bin und auch da steht, das ich eine... |
Windows 10 Support | 6. August 2016 |
