Stuttering and Noise Squealing in Game Bf1 and a bit in Audio Apps, Failures to load some...
Helfe beim Thema Stuttering and Noise Squealing in Game Bf1 and a bit in Audio Apps, Failures to load some... in Windows 10 Support um eine Lösung zu finden; My PC on Windows 10 started having Audio and stuttering problems very recently. Prior to that everything ran completely fine. I had a similar problem... Dieses Thema im Forum "Windows 10 Support" wurde erstellt von Louis-Boba, 6. Februar 2017.
Stuttering and Noise Squealing in Game Bf1 and a bit in Audio Apps, Failures to load some... - Ähnliche Themen - Stuttering and Noise |
Wie kann ich den Default- OS im Linux GRUB Loader ändern?Wie kann ich den Default- OS im Linux GRUB Loader ändern?: [ATTACH] Hallo, um meine Horizonte ein wenig zu erweitern habe ich auf meinem Windows Laptop zusätzlich Linux Mint installiert. Allerdings starte ich im 90% der Fälle weiterhin Windows, daher würde ich gerne den Linux- Loader so anpassen, dass die Windows als Default OS eingestellt wird. Wie... |
Windows 10 Support | 25. Februar 2023 |
Forza Horizon 4 stuttering and framedrops using a wheel controllerForza Horizon 4 stuttering and framedrops using a wheel controller: i Guys,I need your Help!Every time when i plug in my Thrustmaster T150 Wheel Forza Horiton 4 gets a kind of laggy.Its randomly drop the frames. Sometimes its Stuck for a Seconds or two.When i unplug it and play with xBox Controller all runs fine and on constant FPS.Checked the Wheel with Assetto... |
Windows 10 Support | 30. März 2022 |
Family Safety - Apps and Games - Game is not listedFamily Safety - Apps and Games - Game is not listed: Hello,I bought a Windows-10-Laptop for my daughter.She has already a microsoft-Account and she is already integrated in our family.I want to restrict her game time, but the installed game is not in the list, so I can restrict it so 30 minutes a day.Windows 10 is updated, I did all updates.All... |
Windows 10 Support | 19. September 2021 |
after installing new update i cant run a lot of games or apps and a lot of my games or apps...after installing new update i cant run a lot of games or apps and a lot of my games or apps...: After this new big update iI cant run a lot of apps and games also this update uninstalled a lof of my games and apps. I cant even use windows button and search panel, windows installer or updater dont work as well. Weiterlesen... |
Windows 10 Support | 3. Juni 2018 |
Apps & Features: ändernApps & Features: ändern: Ich weiß nicht, was es bedeutet wenn ich bei einer App "Ändern" anklicke. Weiterlesen... |
Windows 10 Support | 19. Dezember 2017 |
Some apps creates a window in a window (store/netflix)Some apps creates a window in a window (store/netflix): Hello, i'm not sure whats the problem, but my computer minimizes apps inside the app. it's a bit hard to explane so just have a look at the screenshot. So as you can see i fullscreened the app but it creates a small window inside the app. i have it in netflix and also in the windows store.... |
Windows 10 Support | 15. November 2017 |
Icon für Apps ändernIcon für Apps ändern: Hallo Leute, ich nutze seit kurzem die Skype-App, die bei Win 10 vorinstalliert ist. Das viereckige Icon finde ich allerdings nicht schön (nutze sonst auch weniger Apps), sodass ich das ganz gerne austauschen würde. Grundsätzlich kein Problem, habe schon öfter Icons ausgetauscht, aber ich weis... |
Windows 10 Support | 21. Juni 2017 |
Audio noises and desynchronisation and bad system performanceAudio noises and desynchronisation and bad system performance: Hello, since I installed the Windows 10 Anniversary update I get cracking noises in audio and HD audio/video streams desynchronize with about one second per minute. Also scrolling in text documents and PDF files cause an overall system slowdown. In adition to that, my mouse pointer does not... |
Windows 10 Support | 4. Januar 2017 |
