Multiple BSOD hardware issue or driver issue ?
Helfe beim Thema Multiple BSOD hardware issue or driver issue ? in Windows 10 Support um eine Lösung zu finden; Hello microsoft community, I got some very frustating issues with my pc and I dont know how to fix it. In the last months my pc got various types of... Dieses Thema im Forum "Windows 10 Support" wurde erstellt von Iriszer0, 14. Oktober 2018.
Multiple BSOD hardware issue or driver issue ? - Ähnliche Themen - Multiple BSOD hardware |
Windows Explorer IssueWindows Explorer Issue: Hello, i suddenly appeared this morning when i got on my work desktop have an issue with explorer where it takes several "attempts" to open a folder. What happens is, that once i doubleclick a folder, the small blue loading circle appears beside the cursor. then the circle disappears and... |
Windows 10 Support | 7. Februar 2024 |
Optical drive issue.Optical drive issue.: Aus diesem Thread ausgliedern. Hallo Herr Johann, vielen Dank für Ihre Hilfe, bin so froh, dass ich mich wieder ganz normal anmelden kann, einfach famos.Aber ich hab noch ein anderes Problem, ich kann keine Recovery CD erstellen, folgende Fehlermeldung, sie Foto.Habe im Gerätemanager das CD... |
Windows 10 Support | 5. Februar 2024 |
BSOD issueBSOD issue: I am trying to find out why this computer keeps getting BSOD errors. I have re-imaged the computer multiple times. Ensured all drivers/BIOS/Windows are up to date.But it still keeps randomly happening....Microsoft R Windows Debugger Version 10.0.19041.685 AMD64 Copyright c Microsoft Corporation.... |
Windows 10 Support | 20. August 2021 |
Windows 10 -ISSUE?Windows 10 -ISSUE?: Windows 10. "Video speichern unter" Funktion geht nicht. Ursache? Lösung?? https://www.gutefrage.net/frage/windows-10--issue |
Windows 10 Support | 14. März 2020 |
Surface Pen IssueSurface Pen Issue: Hi Everyone I have an Issue with my Surface Pen (I have a Surface Pro 4). After trying to connect my Pen to my Android smartphone, I wanted to reconnect it to my Surface. At first everything seemed to work fine until I´ve realized that the Pen sometimes interrupts while writing or writes... |
Surface | 20. Oktober 2019 |
Wake from hibernation - BSOD - several stop codes - hardware issue?Wake from hibernation - BSOD - several stop codes - hardware issue?: Hi community! I hope someone can point me to the right direction. I'm tracking down a computer problem which existed for quiet a long time on this machine. This is my last approch to solve it. The issue: 1. the computer is put into hibernation (this kind of hibernation: "powercfg.exe... |
VPN issueVPN issue: Hallo liebe Microsoft Community, und zwar habe ich auf einem Windows 10 Client zwei Profile eingerichtet und bei beiden Profilen habe ich ein VPN-Profil angelegt. Beim einen Account handelt es sich um einen lokalen Administrator Acc und beim anderen um einen normalen Benutzer ohne... |
Windows 10 Support | 23. Juli 2018 |
Graphics issuesGraphics issues: Hi, I got a very strange issue with my graphics on WIndows 10, which seems be be a broken GPU, but in Safe mode everything looks fine. Here you can see a foto of my desktop: Photo of my desktop And here a screenshot (which looks normal): Screenshot of my desktop I tried uninstalling my... |
Windows 10 Support | 25. November 2017 |
