Display does not lay on chassis in tablet mode
Helfe beim Thema Display does not lay on chassis in tablet mode in Surface um eine Lösung zu finden; Hi Community, i got an replacement device SLS 1 for my old SLS 1, where the surface connect port was broken. When writing on my new device, I noticed a... Dieses Thema im Forum "Surface" wurde erstellt von Florian Dirnberger, 28. April 2024.
Display does not lay on chassis in tablet mode - Ähnliche Themen - Display does not |
Surface Laptop Studio does not detect the Thunderbolt DisplaySurface Laptop Studio does not detect the Thunderbolt Display: I have following Surface Laptop Studio:11th Gen IntelR CoreTM i7-11370H @ 3.30GHz 3.30 GHz64-Bit-Betriebssystem, x64-basierter ProzessorI have an old thunderbolt display from apple with a built in TB2 cable. Connecting to the TB2 cable I have an apple TB2-TB3 adapter. My Surface laptop studio... |
Surface | 17. September 2024 |
Display does not lay on housing in tablet modeDisplay does not lay on housing in tablet mode: Hi Community, i got an replacement device SLS 1 for my old SLS 1, where the surface connect port was broken. When writing on my new device, I noticed a clicking sound each time i touch the display with my hand. This is due to a small gap between the body and the display. It is pretty annoying.... |
Surface | 28. April 2024 |
Windows 11 does not enter Tablet mode when Keyboard is disconnectedWindows 11 does not enter Tablet mode when Keyboard is disconnected: Hi guys, I am using a SP9 i7, 16 GB and I am running into a problem, where when I disconnect my Keyboard the Tablet does not go into Tablet mode until the charger is either connected or disconnected.Inside the Device Manager I can clearly see that the disconnecting of the Keyboard is recognized... |
Surface | 30. September 2023 |
Web-to-App-Linking does not work on Windows 10Web-to-App-Linking does not work on Windows 10: I am trying to implement web-to-app linking for an app and can not get it working. This doc https://docs.microsoft.com/en-us/windows/uwp/launch-resume/web-to-app-linking describes how to enable opening apps directly instead of opening the corresponding web app in a browser tab. To further... |
Windows 10 Support | 4. Januar 2021 |
Windows 10 Key does not activate on new PCWindows 10 Key does not activate on new PC: Cheers, I recently bought a new PC, and wanted to put my old Windows on the new PC. I checked, it was a retail version of Windows, so it should be possible. I got that Windows as Windows 7 and upgraded it later. I found my Key with Key-Finder Plus, and booted Windows using a Boot-Stick on my... |
Windows 10 Support | 11. Juli 2019 |
Windows Sandbox does not start...Windows Sandbox does not start...: You see, i hav checked the box by Windows sandbox and I see it in the Menu but when I start it, then I see only reports for the admin rights... after this nothing happend... i dont see it in the Task Managar and nothing hapnd why? Jonas. Weiterlesen... |
Windows 10 Support | 26. Dezember 2018 |
Windows button does not work.Windows button does not work.: I have read many of the articles about this issue. I have tried several of the proposed solutions; none have worked including SFC, DISM, and Get-AppXPackage. I've rebooted my laptop after each attempted fix with no luck. I have read that I can try to use repair / restore, but that may be loose... |
Windows 10 Support | 31. Dezember 2017 |
Groove does not start on Lumia 950 xlGroove does not start on Lumia 950 xl: Since today the app Groove does not start more. Warm start or shutdown does not solved the Problem. Has any were the same problem or a idea to solve the problem. Thank you for your Support. In German: Seit heute Abend startet die Groove- App auf meinen Lumia 90 XL nicht mehr. Hat... |
Windows 10 Mobile | 12. Januar 2016 |
