Headset only works, if standarddevice for audio in and out, standarddevice for...
Helfe beim Thema Headset only works, if standarddevice for audio in and out, standarddevice for... in Windows 10 Support um eine Lösung zu finden; Headset only works, if it is set as standarddevice for audio in and out, standard for communication on recording is not enough. I would like to have... Dieses Thema im Forum "Windows 10 Support" wurde erstellt von Frank Dreesbach, 4. November 2016.
  1. Frank Dreesbach
    Frank Dreesbach Gast
    I would like to have speakers for music (standard audio out) and my headset for speech-recognition and telephony as standarddevice for communication.
    Why is there standarddevice and standard for communication, if there is no use for standard for communication? You have to use standard for all, the rest won't work.
    #1 Frank Dreesbach, 4. November 2016
Headset only works, if standarddevice for audio in and out, standarddevice for... - Ähnliche Themen - Headset only works
RDP connection only works after kicking myself out of a session
RDP connection only works after kicking myself out of a session: I have a client with a very strange problem.They use a VPN to connect to their work and RDP to access their work PC.That used to work and still does for days at a time, but every few days it stops working in a particular way:Starting the RDP connection works as usual. It shows the log-in screen...
Windows 10 Support 7. November 2024
audio dock not working for mac
audio dock not working for mac: hello, I have a question about the audio dock from Microsoft. This should work for Mac OS. But, the instructions say that I should open the page https://aka.ms/AccessoryCenter and install it. but I can't install it in mac os. So I can't use the docking station for my laptop. I don't know how to...
Surface 14. Februar 2024
Batchfile, for-loop, if-cases, call, rename, ffmpeg
Batchfile, for-loop, if-cases, call, rename, ffmpeg: Hi,mit einem Batchfile sollen Videodateien in ein anderes Format umgewandelt werden.Könnt Ihr mir hier weiterhelfen?@echo offREM loop through current folder and its subfolders and get each filefor /r %%i in *.* do REM if file is a video call the convert-sectionif %%~xi EQU .mp4 call :convertif...
Windows 10 Support 21. April 2023
Batchfile, for-loop, if-cases, goto, rename, ffmpeg
Batchfile, for-loop, if-cases, goto, rename, ffmpeg: Hi,mit einem Batchfile sollen Videodateien in ein anderes Format umgewandelt werden.Könnt Ihr mir hier weiterhelfen?@echo offREM loop through current folder and its subfolders and get each filefor /r %%i in *.* do REM if file is a video go to convert sectionif %%~xi EQU .mp4 goto convertif %%~xi...
Batchfile, for-loop, if-cases: Hi,mit einem Batchfile sollen Videodateien in ein anderes Format umgewandelt werden.Könnt Ihr mir hier weiterhelfen?@echo off REM loop through current folder and its subfolders and get each filefor /r %%i in *.* do REM if file is a video go to convert sectionif %%~xi EQU .mp4 goto convert if...
Was bedeutet „COA for use on refurbished PC only“?
Was bedeutet „COA for use on refurbished PC only“?: Ich möchte Windows 10 über einen usb Stick auf meinem neuen PC installieren welches aktuell noch kein Betriebssytem hat und hab von meinem Onkel einen Key dafür geschenkt bekommen der irgendwo in einem IT Geschäft arbeitet. Auf dem Foto steht neben dem Key „COA for use on refurbished PC only“....
Windows 10 Support 25. April 2022
2020-01 Cumulative Update for .NET Framework 3.5 and 4.8 for Windows 10 Version 1909 for...
2020-01 Cumulative Update for .NET Framework 3.5 and 4.8 for Windows 10 Version 1909 for...: Update "2020-01 Cumulative Update for .NET Framework 3.5 and 4.8 for Windows 10 Version 1909 for x64 KB4534132" kann nicht installiert werden. Der Fehler ist 0x8007000d. Nach dem ersten installieren dieses Update gab es beim Shutdown/Restart ein Problem, die Maschine hatte einen freeze. Das...
Windows 10 Support 8. Februar 2020
Wie kann ich über einen Niknahme an den Foren teilnehmen?
Wie kann ich über einen Niknahme an den Foren teilnehmen?: Wie kann ich über einen Niknahme an den Foren teilnehmen? Hallo Community, ich möchte Ihnen vor nicht gerne über mit meinem vollen Namen auftreten und möchte da einen Art Nikname verwenden. Wie kann ich das am besten erreichen? Natürlich in meinem Microsoft Konto. Vielen Dank für die...
Windows 10 Support 14. November 2015
Headset only works, if standarddevice for audio in and out, standarddevice for... [gelöst]
