KB4103721 - problems after installation "endless reboot/restart"
Helfe beim Thema KB4103721 - problems after installation "endless reboot/restart" in Windows 10 Support um eine Lösung zu finden; Hi, the "2018-05 Cumulative Update for Windows 10 Version 1803 for x64 Systems" is installed and I used a restart. After the restart Win10 ask again... Dieses Thema im Forum "Windows 10 Support" wurde erstellt von JulianIsrael, 9. Mai 2018.
  1. JulianIsrael
    JulianIsrael Gast
    Hi,
    After the restart Win10 ask again for a necessary restart to finish the update.
    Then I restarted again.
    And again, again …
    After that I deleted the KB4103721 - and Win10 installed the KB again - and after the installation Win10 ask again for a reboot. I tried a few reboots but without success.
    I have following Edition
    Edition: Windows 10 Pro N
    Version: 1803
    Betriebssystembuild: 17134.48
    I don't know if this information is necessary:
    Installed Package: Media Feature Pack -> Windows Media Player is active
    Thanks for your support!
    Julian
    #1 JulianIsrael, 9. Mai 2018
KB4103721 - problems after installation "endless reboot/restart" - Ähnliche Themen - KB4103721 problems after
Blue Screen after restart
Blue Screen after restart: Dear Microsoft,I´ve recently started my Computer and everything just worked as it should work for a while... Then, while reinstalling the Minecraft Launcher, I suddenly got a Blue Screen. After having restarted the computer for several times, I still got Blue Screens shortly after logging into...
Windows 10 Support 19. März 2022
PC reboots every 11min after bluescreen
PC reboots every 11min after bluescreen: After a few months of being idle due to a covid lockdown, 2 of our Dell PCs bought in Dec 2020 suddenly keep rebooting repeatedly after 10min and 53sec. They die with a BSOD, this is the log from Event Viewer: The computer has rebooted from a bugcheck. The bugcheck was: 0xdead000b...
Windows 10 Support 18. April 2021
Taskbar resizes after computer restart
Taskbar resizes after computer restart: Since a few days the Windows taskbar always resizes to its initial size when I restart Windows (only after restart! not after shutdown!). Why is this so? I want it to be double sized, not only one row. Weiterlesen...
Windows 10 Support 6. November 2019
Qualitätsupdate KB4103721 wird immer wieder installiert
Qualitätsupdate KB4103721 wird immer wieder installiert: Das Qualitätsupdate "2018-05 kumulatives Update für Windows 10 Version 1803 für x64-basierte Systeme (KB4103721)" wird auf meinem PC angeblich erfolgreich installiert. Bei der nächsten Suche nach Updates wird es aber erneut installiert. Laut Updateverlauf erfolgte die Installation inzwischen...
Windows 10 Support 11. Mai 2018
KB 4103721 Probleme, hier eine Lösung
KB 4103721 Probleme, hier eine Lösung: Hallo zusammen, da ich immer noch neu hier bin, sind mir ein paar handwerkliche Fehler beim Hochladen passiert. Hier nochmal der Link für die mögliche Reparatur des Bugs beim 1. kumulativen update zu Vers. 1803 KB4103721 - So löst ihr das Boot-Problem im Windows 10 Version 1803 Mai-Update -...
Windows 10 Allgemeines 11. Mai 2018
Update KB4103721 - schwarzer Bildschirm
Update KB4103721 - schwarzer Bildschirm: Guten Tag Seit dem 08.05.2018 erlebe ich folgendes Problem: Das Update KB4103721 wird heruntergeladen, beim Aufstarten wird der Bildschirm schwarz und zeigt einen rotierendem Kreis und das System startet nicht (wartete bereits für ca. 10 Stunden). Ich muss nun bei jedem Aufstarten des...
Windows 10 Support 10. Mai 2018
May 8, 2018—KB4103721 Fehlerhaft
May 8, 2018—KB4103721 Fehlerhaft: Nach dem Update startet der PC nicht mehr. Es geht bis zum Normalen Ladebildschirm wo sich der Kreis dreht, der Bildschirm bleibt schwarz und das war es. Ich Frage mich Ernsthaft was Microsoft wieder für Mist Gebaut hat. Muss ich jetzt wegen dem mist mein System neu Aufsetzten oder wie ? Wer...
Fehlermeldung KB4103721 0x8e5e03fb
Fehlermeldung KB4103721 0x8e5e03fb: Habe gestern Abend bei einem brandneuen Lenovo T580 das System aufgesetzt. Alles lief perfekt. Bis ich kurz nach 19 Uhr nochmals das Windowsupdate betätigte. Es folgte die Fehlermeldung: 2018-05 Kumulatives Update für Windows 10 Vers. 1803 für x64 basierte Systeme (KB4103721) 0x8e5e03fb....
Windows 10 Support 9. Mai 2018
KB4103721 - problems after installation "endless reboot/restart" [gelöst]
Schlagworte:
