Second Monitor over usbC dock Problem with my Surface Pro 7
Helfe beim Thema Second Monitor over usbC dock Problem with my Surface Pro 7 in Surface um eine Lösung zu finden; Hi, I used to use a second Monitor with my Surface pro 7 by useing a usbC to hdmi adapter. I dont know why but it doesn't work anymore, the second... Dieses Thema im Forum "Surface" wurde erstellt von Samuel Fleischer, 5. Mai 2023.
  1. Samuel Fleischer
    Samuel Fleischer Gast
    Hi, I used to use a second Monitor with my Surface pro 7 by useing a usbC to hdmi adapter. I dont know why but it doesn't work anymore, the second Monitor doesnt even show up at all. I know that the dock and the cable isnt the Problem as I can use Samsung DEX with no problem. Must be some diver thing? I worked before with the exact same setup! Thank you
    #1 Samuel Fleischer, 5. Mai 2023
  3. hal9000
    Code:
    https://answers.microsoft.com/de-de/surface/forum/all/second-monitor-over-usbc-dock-problem-with-my/640a9a68-486c-4866-b988-3b2732460a10
Second Monitor over usbC dock Problem with my Surface Pro 7 - Ähnliche Themen - Second Monitor over
Verbindungsprobleme Surface Pro 7 zu Monitor über Surface Dock Model 1661
Verbindungsprobleme Surface Pro 7 zu Monitor über Surface Dock Model 1661: Problem: wenn das Surface Pro 7 Betriebssystem Windows 10 mit dem Surface Dock Model 1661 mittels Monitor-Kabel HDMI auf Mini Displayport bereits vor dem Hochfahren verbunden ist möchte es immer und immer wieder die Verbindung zum Monitor herstellen. Es ertönt auch abwechselnd das Tonsignal...
Surface 14. September 2023
Second monitor
Second monitor: Hello. So when I connect only my TV as intended 1. monitor, everything is fine. As soon as I connect a 2. monitor actual PC monitor, windows detects the 2. one as monitor number 1, even when I set the actual first one as my main monitor. I have no idea how to fix that and my patience with this...
Windows 10 Support 19. August 2022
Surface Pro 7 und Microsoft Dock 1: Externer Monitor
Surface Pro 7 und Microsoft Dock 1: Externer Monitor: Guten TagKann ich ein Surface Pro 7, das ich an einem Surface Dock 1 angeschlossen habe, über den MiniDisplay Port externe Monitore anschliessen?Besten DankJoël Bühler Weiterlesen...
Surface 4. Juli 2021
Surface Laptop Pro aktiviert Monitor nicht über Surface Dock
Surface Laptop Pro aktiviert Monitor nicht über Surface Dock: LiebeLeute, ichhabe zwei Arbeitsplätze, an denen ein HP-Monitor HP EliteDisplay E273m an ein SurfaceDock 1 überDisplayPort-Kabel bzw ein SurfaceDock 2über USB C auf DP Kabel angeschlossen sind. Anbeiden Docks laufen problemlos im Wechsel ein SurfaceBook 2, ein SurfacePro 4und ein...
Surface 18. März 2021
MS Surface Pro 7 an Dock 2
MS Surface Pro 7 an Dock 2: Neues Surface Pro 7 I7, 16 GB RAM, 256 SSD mit neuen Dock 2, 2x 24“ HP Monitore über USB-C to HDMI Kabel, Monitore bleiben schwarz, kein Signal, Anzeige in WIN 10....wahrscheinlich benötigen die USB-Geräte mehr Energie.... Monitor direkt am Surface funktioniert einwandfrei, Surface Diagnostic...
Surface 18. Januar 2021
Surface Pro 7 an Surface Dock 2 aktiviert externen Monitor nicht
Surface Pro 7 an Surface Dock 2 aktiviert externen Monitor nicht: Ich habe meine Surface Dock 1 gegen eine Surface Dock 2 ausgetauscht. Dabei hatte ich folgende Konfiguration Surface Go / Pro 6 / Pro 7 --> Surface Dock 1 ---> Surface Adapter Mini-DP auf HDMI --> HDMI Kabel --> Monitor iiyama PL2792Q Neu ist gekommen die Surface Dock 2 und ein Surface USB-C...
Surface 19. Dezember 2020
Surface Pro 7: Angeschlossener Monitor am Dock bleibt schwarz
Surface Pro 7: Angeschlossener Monitor am Dock bleibt schwarz: Hallo und guten Tag, am gestrigen Samstag habe ich die Nerven verloren und mir ein neues Surface Pro 7 zugelegt. Ich habe mich für die Variante mit I5 Prozessor, 8 GB RAM und der 256 GB SSD entschieden. Da ich schon seit einigen Jahren ein Surface Pro 4 besitze, habe ich das Gerät ohne...
Surface 24. November 2019
Surface Pro 7 per Surface Dock: Monitor bleibt schwarz
Surface Pro 7 per Surface Dock: Monitor bleibt schwarz: Ich habe kürzlich ein Surface Pro 7 erhalten, für welches ich demnächst mein altes Surface Pro 4 abgeben werde (Eintauschaktion für Vorbesteller). Problem: Der Monitor am Surface Dock bleibt schwarz, wenn ich das SP7 an das Dock anschließe. Mit dem SP4 funktioniert weiterhin alles tadellos....
Surface 29. Oktober 2019
Second Monitor over usbC dock Problem with my Surface Pro 7 [gelöst]
