Help : Restore my file after using reset options
Helfe beim Thema Help : Restore my file after using reset options in Windows 10 Support um eine Lösung zu finden; Hello I need help, I can not restore my files, after using options resetting windows I choosed the option with: keeping your files now I can not... Dieses Thema im Forum "Windows 10 Support" wurde erstellt von ImaneMohamed, 10. April 2016.
  1. ImaneMohamed
    ImaneMohamed Gast
    Hello
    now I can not find my files, neither Windows.old
    I need to retrieve my files, I used all options but nothing worked
    #1 ImaneMohamed, 10. April 2016
Help : Restore my file after using reset options - Ähnliche Themen - Help Restore file
My PC keeps freezing after closing games
My PC keeps freezing after closing games: HeyIm having a Problem where my Pc keeps freezing After I close a Game this can Happen instantly or take a Bit. I can still move my mouse and select Apps but cannot start them and the Task bar becommed unresponsive. After trying to shutdown my pc using the STRG+ALT+ENTF Screen it just takes for...
Windows 10 Support 22. September 2024
Help me find lost or missing files in OneDrive
Help me find lost or missing files in OneDrive: Guten Tag,seit ca. einem Monat versuch eich an die Daten meines Windows Surface Book wieder ranzukommen. Doch bisher vergeblich. Der Laptop konnte plötzlich nicht mehr bedient werden und lediglich das Startlogo und ein roter Balken mit Schloss war zu sehen. Restart oder ähnliches hat nicht...
Surface 2. Mai 2024
Hello, i need help with my PC
Hello, i need help with my PC: Around 2 days ago i disabled some sort of setting, making it, that only essential program open on startupAfter rebooting, my audiodrivers dont work anymore, and the diagnostics dont recognise the problem either. USB can also not be recognized anymore, and because i have my internet connectuons...
Windows 10 Support 23. Juni 2023
Fehlercode nfts file system nach Hard Reset
Fehlercode nfts file system nach Hard Reset: Guten Morgen, Ich habe gestern Abend versucht meinen Laptop auf Werkseinstellungen zurückzusetzen. Da der Vorgang einige Zeit in Anspruch nimmt, habe ich das über Nacht laufen lassen. Heute morgen zeigt er mir den Bluescreen mit dem Fehlercode ntfs file system an. Er versucht einen Neustart,...
Windows 10 Support 27. Dezember 2020
I need help repairing via .dmp file
I need help repairing via .dmp file: Hello there I've reinstalled Windows 10 Pro About two days ago, did a fresh Installation of it, yet my games like Black Ops 4 or Fallout 76 Keep crashing after About 10 minutes. I've downloaded the Windows Toolkit, but I do'nt understand what to do anyways. So I went to a Website that let me...
Windows 10 Support 19. Januar 2019
Option "Nur 3G + 4G" fehlt seit System Restore
Option "Nur 3G + 4G" fehlt seit System Restore: Hi, da sich meine Fotos App nicht mehr starten lies und keine Anleitung und keine Hilfestellung half, habe ich heute schweren Herzens das Handy zurückgesetzt. Voller Freude dass das eingespielte Systembackup nur gefühlt die hälfte der Einstellungen wieder angewendet hat, ist mir eines doch...
Windows 10 Support 14. September 2016
Help : Restore my file after using reset options: Hello I need help, I can not restore my files, after using options resetting windows I choosed the option with: keeping your files now I can not find my files, neither Windows.old I need to retrieve my files, I used all options but nothing worked [moved from German forums] Weiterlesen...
Windows 10 Support 10. April 2016
Restore Files from 8.1 Backup in 10
Restore Files from 8.1 Backup in 10: Hi Ich bin heute von 8.1 auf 10. Nachdem update hat windows mich gefragt einzuloggen und so sah erst gut aus aber dann waren mein ganzen Datein nicht mehr da. Schnell hab ich herausgefunden das die alle im User Ordner TEMP waren. War ich nicht wirklich erfreut drüber und habe die Datein vom...
Windows 10 Support 30. November 2015
Help : Restore my file after using reset options [gelöst]
